TPS issues
When I first bought mine back in 2009 I had similar symptoms - most often it would go into limp mode if I stopped for fuel after a long drive. Three restarts would clear it each time until, one day, it wouldn’t. In my case, it was a cam position sensor that was at fault.
Inlet or exhaust can you recall?
Have you cleaned the ICV and the butterfly valves on the throttles? You will also need to reset the throttle.
I did clean them before. emm... I think most the time I have the problem after driving through a pothole on highway. After the pothole, I can feel the throttle is not working well. All the lights will come out about 30s after the pothole. I remember I got a code "throttle body briefly stuck" before, but most of the time I really have no codes from INPA or Autel.
