T Tonydevon New member Jan 4, 2019 #1 Looking at 2004 Z4 thats got replacement wheels. The tpms light is up on dash. Was mentioned on mot test. Can it be turned off? Guessing it not cheap to get 4 sender things.
S Smartbear Lifer a barn in Somerset Jan 4, 2019 #2 Tonydevon said: Looking at 2004 Z4 thats got replacement wheels. The tpms light is up on dash. Was mentioned on mot test. Can it be turned off? Guessing it not cheap to get 4 sender things. Click to expand... Hi, a 2004 car doesn’t use transmitters but utilises the abs rings instead
P ph001 Veteran N. Yorkshire. Jan 4, 2019 #3 If its had new wheels it might just need calibrating. Defo try that first, make sure your tyre pressures are all correct before you do it. If it’s a wheel speed sensor you normally get a ton of other lights on as well.
Sidewaze Samm Senior member Sth. Manchester/Cheshire border Jan 8, 2019 #4 Smartbear said: Hi, a 2004 car doesn’t use transmitters but utilises the abs rings instead Click to expand... Do any use the transmitter type, and if so when was the change? With the facelift?
S Smartbear Lifer a barn in Somerset Jan 8, 2019 #5 Sidewaze Samm said: Smartbear said: Hi, a 2004 car doesn’t use transmitters but utilises the abs rings instead Click to expand... Do any use the transmitter type, and if so when was the change? With the facelift? Click to expand... Transmitters came in with the e89 and that was only circa 2014, I’ve got a Sep 13 lci and that doesn’t use them. :? Rob
