So the first cold day we have I get a warning that the right front wheel is low on pressure. I turn the car off, get out and check it and everything seems to be OK. I had a tire gauge with and yes it had dipped to 32psi or so, but still safe to get home. I start the car up and low and behold the car shows all four corners low. Thinking I may have ran over a bunch of debris I get out and check everything thing and find all tires at 30 plus psi so no panic. When I get home I air up to 36 and 39 psi (17in) and everything resets as you would expect.
So here is my question, other than to say it just coincidence, has this happened to anyone else where it goes from one tire to all four and if so has it happened more than once? By shutting off the engine did it rescan and get confused? Second this being my first encounter with the TPMS system does it distinguish between low psi say 32psi and no psi (as in flat)? The manual talks about red and yellow but doesn’t really distinguish much between the two. I assume red is 0psi. And lastly does TPMS monitor pressure at all or is it strictly rotational based? If it’s just rotational based, why not just use part of the ABS to check wheel rotation speed?
