It went off to be tuned Saturday. 280 BHP and 290 ftlb we are quite happy with that.
Machine monkey said:I am getting very tempted to put the v8 from the soarer in my z4!!
Grumpyowl said:Machine monkey said:I am getting very tempted to put the v8 from the soarer in my z4!!
When are you starting.
V8 burble from a Z4![]()
Machine monkey said:Grumpyowl said:Machine monkey said:I am getting very tempted to put the v8 from the soarer in my z4!!
I am very tempted. The gearbox we know we can do. We are working out if my new clutch would work. Engine mounts won't be a problem it will fit. Exhaust might be tricky. It dose not weigh much more and is shorter than the 6 so the weight is more central.
I will be using a standalone ECU if I turbo and the turbo and this would cost about the same? And at 280 Bhp and 290 ftlbs and then a blower 500 ish of each!!
Grumpyowl said:Machine monkey said:Grumpyowl said:When are you starting.
I don't think you've much choice now![]()
New thread MM's Z4 V8 build![]()
Machine monkey said:Grumpyowl said:Machine monkey said:I am very tempted. The gearbox we know we can do. We are working out if my new clutch would work. Engine mounts won't be a problem it will fit. Exhaust might be tricky. It dose not weigh much more and is shorter than the 6 so the weight is more central.
MM's charity thread so he can build his V8!!
Grumpyowl said:Machine monkey said:Grumpyowl said:I don't think you've much choice now![]()
I'm sure it would be a better donation than marmites![]()
Machine monkey said:That's her I will be there st 2,00![]()
Dunk said:Anymore photos of the finished engine bay
Hows it running ?
