adrianjosh
Finisterre said:do you have a manual and have you looked at realoem?
i have a manual but not the official manual. its a PDF file
Stuart Truman said:Look right in the middle of the shelf on the bulkhead and you will see a small slot cut out where a peg from the shelf engages. This is what presses on a small metal lever that operates the micro switch. You should be able to see this when the shelf is in the up position. You can use a pen or small screwdriver to press on the lever and you should hear the micro switch click. If you're careful you can hear it as you move the shelf.
The click doesn't prove the switch is ok, but it's a reasonable indicator. The only way to tell for sure is to put a multimeter across the switch and test it properly
Citation 650 said:You might try lowering then raising the top manually to see if that resets it.
Finisterre said:I don't suppose you could have a faulty switch.
Wouldn't that be good?
I think that would be my next test.
Good luck.
Please let us know how it goes.
jamiez said:Have you tried disconnecting the battery for 10 mins, reconnecting and then trying again?
