Toe in toe out
bluepain
Hi guys I'm after picking of brains again..
I have a tracking issue on the rear of my I sport..
One of my rear tyres is showing signs of high ware on the inside.,only one..
got it replaced last week at a popular tyre garage..
The the uk has..as it's the cheapest place to purchase Bridgestone potenza's currently..
I knew the tracking was out..from the tyre ware .however I didn't trust them to do it...
Anyway ..I know my toe in is out by quite a biton this wheel,
And that the chamber is correct
.(quite high chamber on these)..
I know where the bolts are for adjusting the toe in..they are by the roof top drainage pipe..
But I have a couple of questions..so far every garage has stated I need a special tool to adjust the toe in..
I can only assume it's some sort of jig.that attatches in the area of the two bolts that let's you move the swinging arm in situ before bolting it back up..
1 Has anyone seen one ? Or heard one...
2. I've owned BMW's previously ,and the camber adjustment was on the control arm at the axle.
By way of 2 bolts .one to fasten one to turn to move arm outwards or inwards..
On my z4 just bolts ..no adjustment at the axle.. ?
However the bottom swinging arm at the bottom hub it does have what I expected to be on the axle mounting.
It has an adjustable bolt that would seem to adjust the camber..
So question 2 is..does this adjust the camber....
Cheers all thoughts welcome
The bottom control arm eccentric bolt adjusts the camber. Here is a picture of the tool to adjust the rear tow.
Ok that's the tool..
I've gotta say I'm confused as to how it works?
Can you shed any light on where it fits to make adjustments
