today i...
Jembo said:
... opened the roof outside.
... put 3 bars heating on the seats.
... set the heat to 25 degrees on the feet
Now this may be a novel concept and I admit I'm thinking outside the box on this one,... but...why not leave the roof UP turn the seat heating off and turn the heat down to 18 degree's :) your other half won't be cold then :thumbsup:
Fitted front & rear drop links.
Fronts were easy, rears bloody challenging...
Fitted new Pagid front Discs and Pads which sorted out my vibrations when braking problem.
Fitted new O-Seal to my down hose temperature sensor which will hopefully cure my coolant leakage.
Fixed the heater on my daughters Ford Focus.
Fixed the back gate.
Renewed my Car Insurance saving me £500 a year. http://www.z4-forum.com/forum/viewtopic.php?f=2&t=50379#p731248
You know what........It Was A Good Day.........
[youtube]h4UqMyldS7Q[/youtube]
A good day indeed Jimbo :thumbsup:
I...
Cut the grass for the first time this year
Finalised next weekend's rugby tour
Started looking for a new job, sort of :oops:
Best of all though....
Drove everywhere (e v e r y w h e r e !) with the roof down. All day. Brilliant :thumbsup:
I...
Good luck with the job hunting Bing.
Hope to get out tomorrow for some roof down driving if the weather holds up.
Used a clay bar on the z for the first time :)
Sent from my Samsung Galaxy S3 using Tapatalk 2
I wouldnt say i use it 24/7, think youre confusing me for someone who doesnt have a life :)
Today I finished off the polishing work I started yesterday and then went hooning with the wifey to MK to see friends. Was half an hour late because I forgot how much fun round-a-bouts could be.... :oops:
Today I...
Made an ashtray IPhone mount for my zed (cue plastic, craft knives and areldite!)
Changed the oil and filter
Washed it
Sorted a rattle out behind the hood
Changed brake/clutch fluid and bled everything
Cleaned the DISA valve.
Then had a rest :thumbsup:
...installed a new Brodit mount for my iPhone :D
No pics of it with the phone in place as I was using the phone to take the pics :headbang:
It looks like it blocks the heater controls, but I can still get at them easily with no dramas, and they are on auto almost all the time anyway. I can also reach the phone real easily. It does feel a bit weird having it there - kind of like having a foreign body in my Z's cabin :?
Anyway, next on the list is fitting the Intravee I bought on here - hopefully later this week prior to the Kent Cruise... Cue lots of questions to Messers Truman, Hutch and pvr when I get it wrong :wink:
RJS-Z4 said:
Bing bing bing, did anything have to be removed to fit that??? Looks perfect for my aux install!
Nope, unless you have an M or have fitted a carbon leather dash it comes with tools to fit it. If it's too tight to fit you can remove the centre vents, the stereo head unit and loosen the four screws that hold the dash in place and it will allow just a little more flex.
Today I learned what the expression "freeze your tits off" really means. As a dare with a friend jumped into the unheated outdoor pool at the hotel at 7:00am. Holy crap!
Several precious objects appear to have disappeared... :o
As Stuart says, nope, not with the alu trim. Took me 20 mins to put it all together and ft it :D
The gap tools supplied worked fine - it didn't look like there was a gap as the black trim is a little spongey but the tools reduced the pressure enough to hook the top in under the alu panel. It is very cleverly curved so you can do this - in fact the back mount is specifically designed for the car and the bottom edge just hooks into the edge of the panel that your aux port is in. I did actually pop that panel out a little so I could feel it was fitted just right. You need to buy the back mount for your car and the holder for your phone, then screw them together - that was the trickiest bit and was not tricky :wink:
There's lots of options for holders - I got one with the upright bit at the back for more stability, but you really don't need it as it is nice and tight. There are models designed for phones with and without the apple bumper, and for phones with skins, and you can get holders that have a power connection at the bottom fitted so you don't need to keep plugging in the lead... But they were twice the price of the holder I got and weren't worth the extra IMO. I got the 'without bumper or skin' one, even though I do have a very thin skin on mine, and it fits really nicely.
This is the skin I have, for the 4S but they do them for the 4 and 5, and in 'clear' : http://www.mobilefun.co.uk/ultra-thin-protective-case-for-iphone-4s-black-p32967.htm ... It is really, really thin and follows the moulding of the phone precisely (you need the specific 4 or 4S skin as the buttons are in a slightly different place on each, as I found out :headbang: )
This is where I got the brodit clip and mount - http://www.mountonus.com/ ... Their selection process walks you through the selections so you don't get the wrong parts :D
Hope that all helps. Probably should have started another thread for this topic, with hindsight :oops:
....am going to drive around with my roof up all the time.
NOT !
:driving:
