My roof lining developed a slight rattle when the car got warm. BMW replaced some retaining clips which sorted it.
If you can locate the squeak there's a tape you can buy to put between the "squeaky" surfaces. http://www.ebay.co.uk/itm/25mm-x-2m-x-1mm-MultiPurpose-Self-Adhesive-Anti-Squeak-Rattle-Felt-Strip-Tape-/172773826785?epid=5004992191&hash=item283a1f60e1:g:0eMAAOSwY4pZY0m2
Car manufacturers take this annoyance very seriously and even they sometimes resort to tape.
Chasing down a rattle can be a lifetimes work though.......................
I had this well annoying rattle from the roof locator and removed the inner plastic part, and now it's got enough movement to no longer rattle and my roof is silent!
Hi reading your thread it reminded me i have a rattle sounds like a bunch of keys when i go over bumps or uneven rd
I had suspension checked just in case shook a few things looked under the seats lol
But its is ok when i have a passenger so i try not to let it bother me
Oh cars perfect apart from that
Thanks guys
Seat rollover head cover: This one was obvious once spotted. If you or a passenger push the seat back and it rests against the cover, it creaks like crazy while driving.
Wind deflector: I couldn’t find a solution for this apart from removing it entirely. If anyone has found a better fix, I’d love to hear it.
Front speaker dash cover: This one took a bit to diagnose the source but was obvious once found. The internal cushioning on mine had disintegrated, the cover rests on the cushioning — easy to spot once you open it up (which is simple to do). I found that placing some Blu Tack worked well as a fix
Yes the sun visor must be the cheapest tacky sun visor on a car. I have wedged all sorts in the mirror gap to try stop it rattling. Latest i poured some two part resin inside blanked mirror off.
And i see someone removed the wedge slot, good idea. Only just again put black tape around the wedge to stop noise.
Pity the hole part wasn't made of rubber.
For the hood - Silicon spray on all metal joints and gummy pledge on all rubbers. Mine squeaked alot when the hood was up although very rare I used when up - but now not a sound!!
Again silicon on plastic in the joints and gummy pledge on all rubbers.
