[ref]Argyll Andy[/ref], answers for you below:
What speed did you manage?
--Top speed at the end of straight is about 120-130mph, still more to go but I drove conservatively so lift off earlier than the braking point
Did you feel it still had much to go, as in was it still pulling hard?
--Car was still pulling hard until I lift off. 155mph is an easy job for the car.
How did you feel overall about the handling while pushing it?
--First of all, all the points below assuming the car is for trackday fun instead of racing.
--Overall, the car is way more capable than me.
--Chassis stiffness is amazing for an open top. TBH, you can't feel it as an open top. Way better than the F33 4 series convertable I had before.
--CoG feels very low, suspension in Sport mode gives enough support. As you can see from the photo, the car is almost flat in the corner.
--Brake never let me down despite some vibration after 10+laps. I was told this is normal for almost all oem pad. Even full M car has this issue with oem pad.
--Previously, there were some discussion about m40i being front heavy than 4 pot version. Well, I haven't driven 4 pot G29 so can't comment on the feeling. But I don't think this is an issue.
--Steering is accurate and you can do some micro adjustment during cornering and the car will listen to you. However, many car media reviewers commented that the steering feel is worse than boxter. Well, this is true. It only sends you the necessary information.
Could you feel the LSD doing it’s job?
--Yes, can feel that clearly. It's necessary to put down the power from the B58 when exiting corner. IMO, 20i may not need this. 30i is kind of on the limit of not having this. 40i will certainly need this. However, this also generates some concerns. The way it works is the same between our car and full M car. However, the full M car has the fins on the diff body to help with the cooling whereas our car doesn't. Also, the fluid temp is estimated by the control unit instead of measured by sensor, I am concerning that it may overheat. So, if I keep my plan of doing 3-5 trackday per years, I will look into the cooling a bit further and also change the diff oil every year.
