Hi,
I'm wondering if anyone can help diagnose a recent problem I am currently having. My Z4 (3.0i M54) has been off the road since November 2015 and parked on my drive with an outdoor cover on it since. Last time I started it was during this summer (June) and it started up fine and drove fine (just the brakes were a bit rusted).
Today I started it again to move it. Before I started it, I checked the oil level and topped it up (about 400ml of Castrol Edge 0W-30). I made sure to crank it over to prime the oil/fuel lines and pumps but making sure not to turn the key for long enough to start it. I cranked it over for about 6 times to build oil pressure and then fired it up. Started fine but now I am hearing a ticking/tapping noise which gets faster with engine rpm.
I have attached a video of the noise...
https://youtu.be/wPMpIm9zrf4
I am suspecting it could be a timing chain tensioner as it sounded similar to my MINI Cooper S R53, which were notorious for failed timing chain tensioners.
I had the car idling for about 10 mins to see if the noise would get any better, but no luck. I then just turned the car off and left it at that. It has never sounded like this before - it has always been 'silky smooth'. Last oil change was in 2014 with Castrol Edge Gold 5w-30, but it has only covered approx 100 miles after the oil change...
Could the timing chain be slapping about in the chain guides? I have heard of VANOS chains/units, but not really looked it into it much - can someone explain what this does and if it could be a likely cause?
Any help is greatly appreciated
these cars and
while we still can
