Thoughts on this?
tomscott said:
Meady said:
Busterboo said:
The black & white photos do it no favours, though.
that's true! - I'm thinking of going to take a look at this - https://www.autotrader.co.uk/classified/advert/201805246812146?model=Z4&onesearchad=Used&onesearchad=Nearly%20New&onesearchad=New&make=BMW&radius=1500&advertising-location=at_cars&sort=sponsored&postcode=bn16hb&aggregatedTrim=35i&page=2
Do you think the price is a bit high?
Nice car but again as 2010 and a non M sport its not cheap. Lower mileage cars also are more likely to have injector problems so worth bearing in mind while viewing.
Thanks - haven't really looked at the injector problems, would the fact you mention lower mileage cars being more likely to have injector problems is this due to the fact they are garaged and not driven as much? - Anything that can be checked when viewing/test driving that would point to this potentially being a problem?
Havanah and white extended leather looks amazing op.I have this and the car always gets complimented.18k though that's pricey to give you a rough guide I paid a little over 11 for mine no nav or heated seats and a 6 speed manual but still not 6500 more
As mentioned, they seem to cough&splutter a bit on cold start :?
Busterboo said:
james28 said:
High pressure fuel pump is a problem with these ...
And your evidence for this statement is?
Its a well known weak point (along with the injectors) with the twin turbos starting with the 335i E90s , https://jalopnik.com/5673591/how-fans-forced-bmw-to-fix-this-faulty-fuel-pump
Just the below information and lots of other threads I have read ref hpfp but hey I'm just pointing it out to the op :thumbsup:
I don't have information on how often they go out, but after reading a few very long threads on the e90post forum it's clearly a problem. The e89 Z4 (2009-2010) 35i have the same twin turbo n54 engine the BMW 335i uses which have been plagued by this problem for some time. BMW extended their HPFP fuel pump warranties to 120,000 miles. Even though BMW indicates they have a new HPFP design it doesn't seem to have helped considering that newer cars are still having the problem.
A number of cars are using direct injection fuel systems these days so one has to wonder why BMW can't seem to get this problem corrected. BMW's new(er) 4.4 L v-8 design 1st used in the x6 50i has direct injection fuel systems and I haven't heard of this problem with their engines. Porsche's newer twin turbo have direct injection and to my knowelage no issue. Somebody else may heard something on it. As you stated the Viper and the Honda S2k haven't exhibited a premature failure scenario, either. BMW - what gives?
Conventional advice for in-tank fuel pumps is try not letting your fuel levels drop below 1/4 tank as the pump needs to be submerged in fuel to stay cool and to last a long time (typ 80-100,000 miles). But if the problem as , the ethanol blend is attacking the pump seals, there really isn't much you can do. If that's the case, it should be a no brainer to fix because ethanol based fuels ain't exactly new tek.
The sound from the pump and the 1/2 vs full tank scenario seems counter intuitive to me. I would have expected the higher fuel levels to dampen the sound rather than enhance it, and the 1/4-1/2 full tanks to be louder due to a sound resonance in the tank, but oh well, you learn something new everyday.
Struggling to find a car i'd want at a right price, started to wonder whether holding out for 35i/35is is my issue
have seen this 30i - https://www.pistonheads.com/classifieds/used-cars/bmw/z4-roadster/bmw-z-series-e89-z4-sdrive30i-m-sport-roadster------2010/8718834?utm_medium=EMAIL&utm_campaign=Contact%20Seller%20Program&utm_content=PHDS%20ContactSeller%20Program%20EM1%20(02.02.2018)::vehicle_advert_text&utm_source=20180613
Seems pretty good condition, what's everyone's thoughts?
It certainly looks good, but I can't help much with the price as I don't know much about E89s. :oops:
But being a 30i it will have the earlier N52 engine as used in facelift E85/E86 models, so no HPFP or injector issues. :thumbsup:
mr wilks said:
This not work for you ? https://z4-forum.com/forum/viewtopic.php?f=41&t=105540
It's very nice, especially as it's 35is but no Sat Nav / I Drive is deal breaker for me unfortunately.
I've only been looking 5 weeks or so but getting impatient :driving: :rofl:
