Thoughts on this e86 please
jamesditchy
 Liverpool
Looking to move up from my current 2 litre to this three litre. Wheels will have to go and some paintwork to the lower front. Got someone who can sort the seat out locally but what are you thoughts on the auto box with paddle shift. Never used one before.
Also the roof issue. Motor or not??
Going to view it Monday morning.
http://www.ebay.co.uk/itm/272385266297?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Cheers Jay
GOV.UK
Vehicle MOT History
BETA This is a new service – your feedback will help us to improve it.
Check the MOT history of a vehicle
Registration number: LB56PGZ
Vehicle makeBMW Vehicle modelZ4 Date first used28 November 2006 Fuel typePetrol ColourBlue
MOT history of this vehicle
Test date4 November 2015 Expiry date15 November 2016 Test ResultPass Odometer reading103,411 miles MOT test number7490 2044 0822 Advisory notice item(s)
Road wheel with a slightly distorted bead rim All wheels (4.2.A.1a)
Test date3 November 2014 Expiry date15 November 2015 Test ResultPass Odometer reading98,678 miles MOT test number5954 4780 4347 Advisory notice item(s)
Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
Offside Rear Tyre worn close to the legal limit (4.1.E.1)
Under-trays fitted obscuring some underside components
Test date30 October 2014 Test ResultFail Odometer reading98,598 miles MOT test number8452 1340 4393 Reason(s) for failure
Parking brake: efficiency below requirements (3.7.B.7)
Test date16 November 2013 Expiry date15 November 2014 Test ResultPass Odometer reading96,870 miles MOT test number3396 8032 3319
Test date9 November 2012 Expiry date8 November 2013 Test ResultPass Odometer reading90,486 miles MOT test number6767 9401 2376 Advisory notice item(s)
Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
Nearside Rear Brake pipe slightly corroded (3.6.B.2c)
Front Brake pad(s) wearing thin (3.5.1g)
Rear Brake pad(s) wearing thin (3.5.1g)
Engine covers fitted obscuring some components in the engine bay
Test date12 October 2011 Expiry date11 October 2012 Test ResultPass Odometer reading66,562 miles MOT test number2990 3558 1240
Test date6 October 2011 Test ResultFail Odometer reading66,389 miles MOT test number5154 8977 1283 Reason(s) for failure
Offside Rear coil spring fractured (2.4.C.1a)
Test date15 July 2010 Test ResultFail Odometer reading38,761 miles MOT test number2225 9639 0406 Reason(s) for failure
Front Windscreen washer provides insufficient washer liquid (8.2.3)
Test date15 July 2010 Expiry date14 July 2011 Test ResultPass Odometer reading38,761 miles MOT test number2701 0619 0196
Test date16 November 2009 Expiry date28 November 2010 Test ResultPass Odometer reading33,098 miles MOT test number4626 8012 9462 Advisory notice item(s)
Keep an inspection on rear tryres tread
Mot history seems ok you know about the wheels,the seat, may need windscreen if not been done.
Springs are common and brake pipes, these cars are 10 yrs + now.
Have roof motor relocated into boot.
Is that an after market exhaust ? Will it drone ? Too noisy?
Good colour combo
But You need to go and see it and drive it to see if Auto is what you want.
If it's cheap enough with little spend could be made into a nice car.
I would never buy unseen. Good luck viewing Monday.
Jay it's an E85 roadster the E86 is the coupe.
The auto whilst less involving on those weekend runs is no slouch & when pushed hard feel much quicker from the off than Si manual
Roof isnt the kick in the stones it once was but allow £250ish
Front bumper (lower edges ) needs attention allow £200ish
Factor in a decent service £200
Wheels :rofl: epic disaster & allow £400/£500
Seats aren't heated & again require a makeover which is doable with time & effort allow £50ish
Car if mint 105k auto on decent shoes ? £5500 / £6500 :?
Certainly a nice colour combo but based on the above & should the car check out on paperwork & drive well / sound right / feel right i would set your figure around £4/£4500 :thumbsup:
greed with Mr Wilks, although I would add another couple of hundred quid on there for unforeseeable items as well just in case.
EDIT: my 100th post! whoop! :crazydude: :crazydude: :trampoline: :driving: :happyclap:
Don't sweat it with the auto. When I was buying, for the first time ever, I decided that I would just see what turned up, auto or manual. I ended up with an auto. I occasionally miss having a manual, but only very rarely. It can be pretty much just as involving in its own way. I've heard that the manual box isn't one of the better ones anyway (and I was sure to be disappointed with that after a Type-R Honda), but you can change the gears yourself in Sport+Manual mode, so you get just as much control in the bends using the stick or the shifters on the wheel. Some people say they don't use the wheel shifters but I do actually use them occasionally. Its great when you're just trundling from A-B, so lazy and effortless. I'm not sure I'd ever own another manual again unless I had more than one car (like a toy for the weekend and a daily driver), but I guess I'm getting old and lazy :D
My main thought is that it's an E85!!
Otherwise worth a look I think.
Hope you become a Zed owner soon. :)
Hi James. Enjoyed our run out last Sunday...an excellent day. I agree with the other comments already made. It's a nice colour/interior combination, the autobox + paddles will give you the best of both worlds. The wheels are hideous but is an easy fix, as is paint and roof motor.
A nice car although the mileage would be a bit high for me. Hope it checks out ok on Monday. Keep us posted. :thumbsup:
Actually one other thing I forgot to mention about the auto seeing as its my first, [in manual mode] its kind of quite amusing that it can change gear quicker than I ever could and I don't even have to lift off the throttle, so in a way I can imagine its actually quicker in the real world.
No need to imagine mate , i honestly believe in 99% of forum drivers a auto 3.0Si would be away to 60 quicker than a ///M :wink:
The autoboxes aren't sluggish at all & with sport button on feel mighty quick with foot hard down :driving:
Well going to view Monday morning and if it drives right and the price is right it's going home with me. The there's just the case of trying to sell my 2 litre which has been a pleasure to own.
The add says electric heated seats - they aren't heated. Wheels are awful and tailpipes are very odd too. That ink stain on the drivers side could be a bugger to remove - may require whole seat painting. Colour is right IMO and if its an auto you're after then I guess it comes down to how it drives on the day and whether you can buy it at a price that allows you to sort out the cosmetics.
Beat me to it.
E86 has a tiptop.
Facelift roadsters are still E85's.
Not my thing though, wheels are easy fix, but colour combination for me :cry:
I have to agree that paddle shifting is fast. My previous car, the 2003 Porsche Boxster S had "Tiptronic" switches on the steering wheel, and I found that I could preselect a lower gear before entering a corner even if I were going too fast for that gear. The car would not downshift if I were going too quickly, but as soon as I braked for the turn and then hammered the throttle I was already in the correct gear and rapidly on my way. I have not yet tried this with the BMW but I presume that the same would apply. Maybe next year after I replace the Bridgestone Potenza run-flats with conventional Michelin Pilots ?
David
Well just been to see this today. Although the body work was in good condition, the trader who was just pssing it on failed to mention in the advert that there was a hole in the roof, although he did promise me that it didn't leak haha.
I asked him his reserve and he wouldn't tell me but did say that the cheapest on around was about 7 grand. Very optimistic me thinks. This ones not for me, the search continues
WTF is wrong with traders. A hole in the roof of a cab and he doesn't mention it on the spurious basis that it doesn't leak. Tosser.
I trust you suggested he pay you expenses and for the time you wasted on a fruitless journey.
