With your recent run of bad luck i'd suggest u make absolutely sure you ground urself before tinkering, just in case :wink:Ducklakeview said:Chris_D said:Try a different HU and see if u get same?
If u get the same result, try swapping a new speaker in.
If it's not speakers then i'd be lookin at cables - there's resistance in cables. :wink:
Still a really perfect opportunity to swap in some new caps to one of the amps imo and u can also do an A-B listening test to compare seein as u'v got two identical working amps.
Lucky b@stid![]()
I'll probably recap my own, and refit it, once I find the problem! These amps are more expensive than the roadster side covers! There's only one on Ebay and it's over £330
Mike
