I've put the H&R E46M3 ARBs on my Z4MC knowing full well that some people have ripped the mounts. However, as Beedub says, I think it's only when you have them on the stiffest settings, and IMO that's with the Ground Control ARBs, which are stiffer than the H&R ones. I've put some 6mm shims under the front ARB brackets which I consider should considerably strengthen the mounting points without the need to weld.
