Have owned the car since 2012, I’m good at routine maintenance, but it feels like I’ve been hit with the bad luck wand atm.
2022 had rocker cover gasket changed along with Vanos solenoids, had brake lines replaced due to corrosion.
Was having handbrake issues, had it in, garage who told me it was the shoes, took it to a bmw specialist, they’ve the proceeded to tell me
Pads, discs are screwed, so I should really do the all.
They also said the rocker gasket was leaking, I think they’d forgetten they’d done it.
Also saying my rear brake lines are corroded, but I had them all done. Or maybe it was just the fronts, I need to check paper work.
So should brake lines rust that quick? Gasket screwed already? They said the plastic rocker covers can warp over time? How many of you lots have experienced this? I don’t mind getting work done just don’t wanna get ripped off.
Then I’ve got an elderly parent / kid now so holding onto a 2 seater is becoming more of a heated debate in the house is it wrong to love a car so much
... and a braver person than me might even say which it is
