The dreaded Increased battery discharge warning
Nanu
Veteran
 Sunderland
I know this has been the subject of several posts but I have never understood fully what this problem is and how to cure it. Can someone in very laymans terms explain how I can travel 3 miles to my local supermarket with no warning then on my return the warning is there. Sometimes I can go a week without using the car and no warning then for no reason the next day it appears. sometimes I have to reset it and sometimes it just goes away withou having to do anything. The car is 5 years old so it shouldn't be the battery but would a battery charger help?
It does sound like the battery, they can be weakened at that age especially if it’s been allowed to flatten previously.
Charging just masks the problem of a battery not holding its charge very well :?
A few years ago I got this every now and again in the X6.
It didnt really make sense as sometimes the warning would show up after a minute of the ignition being off and other times it could be 10 minutes or more.
Long story short, one day the car wouldnt start as the battery was dead with no other warning. The car was parked in front of the garage with our other car in it and with the auto gearbox and electric handbrake it couldnt be moved.
I would replace the battery before you get stuck.
Look for parasitic drain on the car...and get a larger capacity battery installed when you change it...BMW battery's arnt all that only 2 year warranty...
these batteries last, mine served 9 years - when they start going out, one of the first signs is the increased discharge alert
Don't forget that these cars have regenerative charging systems so the alternator will only cut in and start to charge whilst the engine is slowing down i.e when you are braking. So, if your short journey is mainly all on the throttle then the battery will not get much charge.
These prolonged periods of inactivity plus short drives doesn’t do these systems any good...
I’ve had to charge my E88 twice this year due to inactivity...
My Volvo XC70, similar age and limited use has had similar issues..
Normally after 6-10 miles it tell me that auto stop/start is available...for the last 3 months due to very limited use and a charge it’s never become available ...
So it’s a mixture of battery age/lack of use / limited mileage ..IMHO..
They do charge at other times as well if needed, otherwise cars would be getting flat batteries on long motorway journeys when there’s barely any slowing down or braking going on :thumbsup:
Then I stand corrected :wink: :thumbsup:
Thanks Guys. A mix of ideas but on the whole battery on the way out sounds to be the concensus. Must admit for the sake of £30 I am tempted to see if giving it a charge makes any difference as I believe new batteries for the Zed are not exactly cheap, then there is confusion which again I dont understand around coded or not. On the good news front the last couple of week have given me the chance to do a full valet and it looks great.
If it’s the battery not holding it’s charge so well, charging will only paper over the cracks & you also run the risk of the dreaded handbrake failure due to low voltage occurring and having to get updated software installed :cry:
A replacement battery of the same spec needs registering, a different battery will need coding :thumbsup:
I’d keep an eye on the battery voltage after the cars sat for a few days, if it gets near 12v you’re on thin ice.
I noticed that my glovebox light stays on when I lock the car if I leave the glovebox open! This accounted for my battery drain warning as I leave the car in storage for long periods regularly.
Also do you have a dash cam with a movenent sensor? If you do turn the camera off before you leave the vehicle in your garage.
Thanks butI have checked everything for the increased battery charge even unplugging Alexa I fitted and still get the warning so thinking its the battery.
As for which battery and posts such as "needs registering, a different battery will need coding" you may as well be talking Vulcan.
Judging by the differences in prices the internet appears to be the way to go rather than a garage but it would appear gone are the days when you just take the old one out connect up the new one and away you go.
All sounds scary.
These guys have been used by several owners from here with good reviews https://www.tayna.co.uk/
Thanks,
Just sent them an email for advice re which battery and fitting / coding / registration requirements.
Well I have had a quote from them and they recommend a S5 A08 BOSCH AGM CAR BATTERY 12V 70AH TYPE 096 S5A08. delivered for £132 but not fitted.
They say this is the only model that comes with a BEM code???? I presume this is a code that needs to be programmed somehow into the car. Any experts out there who can clarify this or instruct a mechanical novice how to fit the damn thing.
Love driving it but know sod all how to fix it :?
Sounds like a reasonable quote and you can't go very much wrong with Bosch, hopefully.
*** They have just got back to me again and confused me further if that was possible. They say that if the car doesn't have ECO START/STOP technology (Which thankfully it doesn't) then you can use any other brand of 096AGM as it more than likely won't require BEM coding however the battery still may need coding back to the cars ECU. :cry:
If the battery is the same rating (AH) as original it will just require registering - this notifies the car the battery has been replaced by one of the same spec.
If it’s a different AH rating, the car needs coding - this alters the charging to suit.
Something like Carly or similar can do both jobs by plugging into the obd :thumbsup:
Look at the Carly owners location thread on here, you could find someone prepared to do this for you :thumbsup:
35is came with the 80ah version in most markets the 70ah was for less powerful versions..
FWIW OP my only experience of an AGM battery was in my 1 Series, and that didn't make it to 5 years either despite the car getting frequent use as it had done 55K miles. Mind you it did have stop/start which I don't think helped! And it did need coding. The only good thing was the amber light on the dash before it actually died.
By comparison the non-AGM battery in my 2nd Coupe lasted 10 years. :?
