The car wont start after cleaning the injectors
Hasse said:
( i.e. how strong is 3 bar)?
3 bar is about mains water pressure. But because of the tiny valve thats tough to estimate. Ideally you should hook up a pressure meter if you want to know the exact value.
What is the exact current state of your car? Doesnt it run/start at all or do you get the emergency program (~1300rpm stationairy with no throttle response) when driving ?
This could turn in to a 'Talk down Striker' saga :popcorn:
(Airplane 2) https://youtu.be/6epe9cFQ_9c?t=33s
:wink:
******* Just injecting a bit of much needed humour to the forum with this ******* :)
:wink:
:lol:
Comedy's good in any situation...
[youtube]BzrI15uw92k[/youtube]
On a more serious note for the OP here is some relatively easy to read info on the system (about which I profess no specific knowledge) page 37 mentions that the DME will selectively cut of injectors if sensor readings or misfire faults are detected, so as intimated by several contributors there are many possible reasons for your symptoms (which may show in your fault code log). Hopefully this article helps with understanding what is a very complex system (for anybody like me brought up on needle jets and points anyway :) )
BMW E85 M54 DME and fule management systems Info http://www.bmwclub.lv/files/04a_MS45_DME_Part_2.pdf
:wink:
:lol:
:rofl: :rofl:
You know where you are with jets and points....
That's why I refuse to convert my classic mini to electronic ignition.....
