Ducklakeview said:I already have a few sets of the Halfords ones John in both fixed head and flexible ratchet, yes they are good, especially for the price with a trade card - BUT I like the fact that the Teng allow you to change direction with the lever, and the 13 degree offset improves access over the fixed head, without going to the bulkier flex headed ones. For some jobs, the lower profile tool makes all the difference.
Mike
john-e89 said:Ducklakeview said:I already have a few sets of the Halfords ones John in both fixed head and flexible ratchet, yes they are good, especially for the price with a trade card - BUT I like the fact that the Teng allow you to change direction with the lever, and the 13 degree offset improves access over the fixed head, without going to the bulkier flex headed ones. For some jobs, the lower profile tool makes all the difference.
Mike
Have to be honest I haven’t seen those with the lever Mike, I’ve not bought any mechanics tools for years. Had my head stuck in builders gear instead.
A set of those will be winging their way over forthwith. Just shows I need to get back up to speed with tools.![]()
Ducklakeview said:john-e89 said:Ducklakeview said:I already have a few sets of the Halfords ones John in both fixed head and flexible ratchet, yes they are good, especially for the price with a trade card - BUT I like the fact that the Teng allow you to change direction with the lever, and the 13 degree offset improves access over the fixed head, without going to the bulkier flex headed ones. For some jobs, the lower profile tool makes all the difference.
Mike
Best price I've found on the 10 piece 10-19mm, inc the 16 & 18mm is here.. https://www.toolstoday.co.uk/teng-tools-10-piece-ratchet-spanner-set-10-19mm?gclid=Cj0KCQiAiKrUBRD6ARIsADS2OLkwpZ7ZEGLLaTDEbCgsZG1tBMKZaMiaFD0XsUQ9efFbzZy50uS389AaAq6gEALw_wcB
Mike
markalp said:£165 for a few spanners .. I could have quite a few beers for that and forget about all the stuff my car needed doing to it with the spanners![]()
patriot66 said:Hi Mike
Amongst all my tools I've got several of these Teng ratchet spanners and without a doubt they get used the most. Superb spanners. They've been faultless. Had them maybe 9 or 10 years now. Would definitely buy a full set when my others eventually die.20180219_171252.png20180219_170425.jpg
Ducklakeview said:patriot66 said:Hi Mike
Them's the one's - Do they have a slight angle on the ratchet head?
So you'd recommend?
Mike
patriot66 said:Would definitely recommend Mike. I've got a fair bit of Snap On like you but tbh these are just as good but maybe just not as sexy looking !
The angle on the ratchet end is maybe only 15/20deg but it's enough to stop your knuckles from getting skinned if working on a flush nut or bolt. The little lever rocks about its centre but is robust enough...I've not broken one !![]()
Ducklakeview said:patriot66 said:Would definitely recommend Mike. I've got a fair bit of Snap On like you but tbh these are just as good but maybe just not as sexy looking !
Link sent to the Wife
Mike
