Hi guys,
Many searchs yielded no results.
2003 E85 z4, 70K miles.
Problem: when the temperature outside is over ~50+ F the car starts fine. When the temp is below and the key is turned to on position the temperature gauge jumps to hot and stays there, when this happens the engine cranks over but wont start.( normally it turns to hot and clears back to cold before start) Sometimes if i let it sit in the on position for 5-10 min and its between 40-50 outside it will clear, after which the cars starts as it should.
any ideas what is causing this?
Thank you! and happy new years!
