Hello from Hong Kong,
I just did some research these few days and come up I will need to do the following, am I missing anything?
Thumb up for [ref]mac27040[/ref] - lighting experts
1. Move pin 4 (side light) to pin 3 (question: how can I find the pin ordering on the connectors?)
2. Connect low beam wire to high beam wire, and then connect high beam wire to 8 bi-xenon
PRE-FACELIFT WIRING
1. RAIN SENSOR
2. LOW BEAM
3. HIGH BEAM
4. SIDE LIGHT
5. HAZARD
6. HAZARD
7. INDICATOR
8. BI XENON
FACE LIFT
1. RAIN SENSOR
2. LOW BEAM
3. SIDE LIGHT
4.
5. HAZARD
6. HAZARD
7. INDICATOR
8. BI XENON
3. Last but not least, recoding via NCSexperts to solve the light bulb error code, can anyone help me out on this? this will be my first time to do recoding... Thanks All
CC_STANDLICHT_RECHTS nicht_aktiv Check Control (CC) - parking lights - right
CC_STANDLICHT_LINKS nicht_aktiv Check Control (CC) - parking lights - left
WARMUEBERWACHUNG_SL_LI nicht_aktiv Hot monitoring - parking lights – left
WARMUEBERWACHUNG_SL_RE nicht_aktiv Hot monitoring - parking lights – right
KALTUEBERWACHUNG_SL_LI nicht_aktiv Cold monitoring - parking lights – left
KALTUEBERWACHUNG_SL_RE nicht_aktiv Cold monitoring - parking lights – right
KALTUEBERWACHUNG_FL nicht_aktiv Cold monitoring - high beams
WARMUEBERWACHUNG_FL nicht_aktiv Hot monitoring - high beams
PRE-FACELIFT WIRING
1. RAIN SENSOR
2. LOW BEAM
3. HIGH BEAM
4. SIDE LIGHT
5. HAZARD
6. HAZARD
7. INDICATOR
8. BI XENON
FACE LIFT
1. RAIN SENSOR
2. LOW BEAM
3. SIDE LIGHT
4.
5. HAZARD
6. HAZARD
7. INDICATOR
8. BI XENON
