AndyMitton
Hi, my first post here. I bought a 2004 Z4 3.0 a few weeks ago and have a few little niggles.
The car has 65000 miles on it and has a full service history and the M Sport suspension - 18" 108 wheels too.
I've done a lot of reading about but still got a few questions...sorry there is quite a few but I'll try to be brief.
I do all my own work on the car (as I've done with previous cars) - I serviced the car this weekend (Castrol Edge 0W30 LL04 spec oil, filter, air filter, pollen filter, plugs etc. and a thorough inspection)
I've had a noise that sounds like its coming from under the gearbox area.
It happens when I set off in first and change to second. Its kind of like a clunk.
I've read a lot on here and it looks like it could be the input flange on the diff - but it does not seem to be coming from that far back on the car. Its almost like its coming from the gearbox. If I drive along in first then dip the clutch to 'unload' the engine the noise happens.
When inspecting the car I took a look at the fron wishbone rear bush. Applying some load with a bar it was easy to see the inside of the bush moving; not a huge amount but it was easy to move (albeit with a lever). Not too sure how much play should be in them to be honest.
There also seems to be a rattle over undulating surfaces (ARB drop links? these did 'seem' ok).
As the engine mounts to the crossmember which the wishbone bush bolts to (and hence the engine torque reacts through this bush) I wonder wether this could be a cause of the rattle.
In addition to this the car does seem to wander over the road really noticeably.
Another problem is the plastic dust cover for the rear shock absorber has split. I've seen a gaiter type rubber cover for sale but this is a fixed length plastic one. Does anyone have any experience of this?
In light of yesterday's service (I was considering doing this anyway as I did a similar job on my previous car - Fabia VRS - and it made it into a new car - huge difference) I was considering purchasing the following: http://www.ebay.co.uk/itm/BMW-E46-FRONT-LOWER-SUSPENSION-WISHBONE-CONTROL-ARM-ARMS-BUSHES-MEYLE-HD-LINKS-/170934367719?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27cc7b75e7......These&clk_rvr_id=461650654845
I've read some good reviews of the more recent Meyle HD components. I would usually use the Lemforder parts but the price difference really is worth it from what I have read.
Must add that the car is great. Engine is fantastic. Just seems to lack a bit of precision which looks like could be due to the bushes. All suspension parts do look asif they have been there from new (the wishbone bushes maybe look a bit newer than the rest).
Any other advice for anything I have mentioned would be much appreciated.
Andy
Also I forgot to add that when I took the spark plugs out there was a bit of oil on the threads (didn't 'appear' to be on the electrode I don't think). It was only really visible on cylinders 3-6 but may have been present on all. Does this sound like a leak on the cam cover gasket? Cheers
Andy
