suspension OEM
Arsouille
 south France
Hi,
This weekend, stroll to discover a little more the Z4.
The suspension is too low and I would like to return it to normal height(Eibach -25mm front and -15mm rear).
I found the OEM springs but wanted to know if there is better?
I have the adaptive suspension (M technique).
Have you already tested other original height springs?
Regards,
Sorry, i don't speak english very well :? :? :? ...(I'm french)
I wanted to talk about coil sping.
I found OEM 33536785087 to rear axle and OEM 31336785080 to front axle.
Did you have test other springs than the originals for the original height?
I don't think there's any aftermarket springs with original ride height. If Eibach made some I'd be the first person to buy them!
If you want OEM springs for the M Adaptive Suspension for a 35i or 35iS then you want the following:
Rears:
LESJĂ–FORS rear coil springs Part No: 33536785087 & 33536785088 (M-adaptive suspension)
Link where I had them installed.
https://z4-forum.com/forum/viewtopic.php?p=1663148#p1663148
I'm not sure for the front as they didn't need replacing.
Beeacon said:
If you have adaptive suspension, how come you only have a single exhaust. Is yours a 30i?
I believe adaptive suspension was an option across the range, in the UK at least. Don't forget different markets have different specs.
Thank you for your answers.
My car is a 2.0 so only one exhaust exit
I ordered springs, I hope it's the right ones.
Anyone know the original body height for the front and rear?
Coil springs received.
Now i do to put them
My car was too low with eibach coil spring.
I found the original height spring (like Beeacon )
the works here : https://z4-forum.com/forum/viewtopic.php?f=11&t=119892
