Supercharger-like whine from engine? 2006 Z4M
jontZ4M
Hi guys
I've been increasingly noticing a supercharger-like whine from my car.
First I assumed transmission, but I pretty much ruled this out when:
A) realising that idle is present when car is static.
B) pressing/releasing clutch makes no difference to whine.
Next I assumed aux pulleys, so I removed aux belt and AC belt:
A) all pulleys feel fine
B) car still makes whine with belts removed
So as far as I'm aware that rules out transmission and aux area of engine.
Other things of note:
- whine is directly linked to RPM
- hard to locate but gut feeling is it's coming from front/top of engine. (I've had a listen around this area with stethoscope but can't confirm it).
- car is 51k miles. I'm the first "enthusiast" owner so I doubt it's had any kind of re-built work.
- no other problems or warnings etc.
What do you reckon guys?
Someone install a Vortec while you wernnt looking?
All BS aside, you removed the belts you said and still the whine? I'd prob look at the chain guide then?
I had a noise like this a bit, when cold only, it was either the water pump bearings or idler pulley. Replaced it all and it went away.
Hi,
I had a similar noise to what you describe but on an n52 (3.0 not the M 😭).
Had the alternator replaced under warranty as part of the investigation, which didn’t solve it.
It turned out to be the oil filter vibrating. It wasn’t seated properly in the housing lid so could vibrate.
Not sure if it’s a similar set up in the M but could hopefully be an easy fix!
Is the car new to you and has the noise been there since you got it?
