Simon 3.2M
Just wanted to clarify with the experts on the forum, are all rear subframes across the Z4 range (excluding M) the same ie 2.2, 3.0si etc - ive heard the E46 is the same frame too?
What he said.AndyBeech said:If you click on the part number on Real OEM it'll tell you what other cars that part fits / is used on. For example, if you search for the subframe on a 2003 Z4 it'll tell you that it's the same part number across the whole pre-facelift range so you know that the same subframe is used in all those cars. So not sure how collecting Model numbers / VIN's will help? :?
Can't help with your question OP but pre-facelift Z4's all used the same subframe. Facelift cars seem to have different subframe's but that doesn't mean they're not interchangeable.
