A
Anonymous
Guest
The car to make them fit
You basically need to butcher the plastic, particularly on the right hand side. The fit on the rhs was not the best for me, left was pretty good, but you can see that the parts are not made for each other if you look closely at where the plastic indents for instance.mike1 said:Thanks for the info guys, any idea what needs to be modified on them? Thanks again for your time, Mike..
PerryGunn said:When I fitted my Strong Strut, I also fitted couple of plain black tower caps - they're a bit flatter and, IMO, finish it off quite nicely
They're available as part of the large accessory kit for the StrongStrutXMetal said:Where did you get those caps? I have a set of Strong Strut as well. Thanks.
PerryGunn said:They're available as part of the large accessory kit for the StrongStrutXMetal said:Where did you get those caps? I have a set of Strong Strut as well. Thanks.
Mine fitted fine - just used a small amount of trim tape to hold them firmly in placeXMetal said:PerryGunn said:They're available as part of the large accessory kit for the StrongStrutXMetal said:Where did you get those caps? I have a set of Strong Strut as well. Thanks.
Oh...didn't know it was from StrongStrut. I got a set from them and it wouldn't fit properly without some modifications, which is why they're still sitting in my drawer. Did you have to modify yours to fit? If so, what did you have to modify to make it fit?
PerryGunn said:Mine fitted fine - just used a small amount of trim tape to hold them firmly in place
