Strut Front Bar
The strut was put on by the previous owner. As I only have a top brace I didn't need to use a car lift for it.
Beeacon said:
The only thing that it is a minor annoyance is if you ever want to remove the engine cover, you need to remove the strut and the 6 nuts that hold the strut down to lift the engine cover. It is to be expected with any over the top strut to be honest, but worth considering if you lift the cover frequently.
Hinged strut braces are available that swing out of the way of the engine without detaching them from the towers. Adjustment for length and, therefore, tension is also available, I believe.
9designs said:
So those that fitted one, has it made any improvement to the front end?
I personally think it has given the front a bit more of a positive feel when changing direction.
