O oo7ml Active member Nov 11, 2012 #1 Hi, some mornings when i start my car up, i hear a strong mechanical grind noise when the ignition is switched on. Does anyone know what this sound could be. My car is due a service in 1800km Thanks in advance for your help...
R Rydal Member Nov 11, 2012 #2 Almost certainly the starter motor taking a moment to disengage. I had mine replaced under warranty although I believe it can often be sorted with some lubrication. I expect its most notable when starting from cold in the morning?
D dario Senior member Nov 11, 2012 #3 is it first stage ignition? Like before you start the engine and you just get the dash light on?
M micz4 Senior member Hayling Island Nov 11, 2012 #5 I concur with the starter motor diagnosis but it's impossible to be sure without hearing it.
O oo7ml Active member Nov 11, 2012 #6 Hi, thanks for all of the replies... yes it is only on cold mornings and it is only when the ignition turns the actual engine on
R Rydal Member Nov 11, 2012 #7 I might have misunderstood, if its not when you actually start the engine, do you have xenons?
R ranski Elite Sutton Coldfield Nov 11, 2012 #8 oo7ml said: Hi, thanks for all of the replies... yes it is only on cold mornings and it is only when the ignition turns the actual engine on Click to expand... Common problem if this is the case - there are a couple of threads on this
