I almost hesitate to ask thinking maybe it is a bad sign of something but...
Seems like every car I have ever owned, the best time to get an accurate measurement of the oil level is after the car has sat over night and the level is at it's highest on the stick and any excess has moved down the stick to the same level as the oil in the oil pan...only makes sense.
I got my Z4 on 10 February, the P.O. had the oil changed for me a few days before I picked it up. I drove it 530 miles home and have easily put another 500 miles on it. So there is at least 1000 miles on this oil change. It is not, noticeably, using any oil. When reading the oil after the car has been shut off for awhile, the oil level is right at full.
Here is the weird part. If I check it in the morning after not running all night, the oil level reads high on the stick, not just a little bit but a lot. If I then wipe off the stick and recheck the oil, I get a proper reading as up to the top mark. This just doesn't make much sense to me. I do have a 98 Z3, 1.9L and it does not do this...nor has any other car or truck I have owned do it either.
I have done this more than once and always with the same results. The oil does not show signs of water in it, the car runs great, no weird smoke coming from the exhaust. My garage floor is level.
I just went out to the garage and checked again prior to submitting the post...same result. First check oil level was up to the top of the brown plastic piece, wiped it clean, put it back in, pull it out and the level was at the full mark. There is some oil at the top of the plastic piece (like at the cross shaped cross section) but the oil as anyone would read it is at the full mark. Waited another 20 minutes before posting. The "oil creep" had already started. However, pull, clean and recheck...perfect oil level !
Is this normal to the 3.0 engine or ...???
Signed,
Confused
Signed,
Confused
