Strange indicator behaviour E85
samZ4M
 Oxford
My indicator has just started playing up, it only seems to be the left signal, but if I put it on, then do the turn, sometimes it's not self cancelling, but sometimes it does and I can cancel it if I want. Right seems fine.
I initially noticed as my "soft push" indicator flashing 4 times (thanks to programming from the Intravee II) has stopped. So I push it and not just get the 1 flash. I've also lost it from my stereo, so assume it's disconnected. Not sure if these are linked, as if it's disconnected, surely the self cancelling would work?!
I will check the intravee connection and see if it's lose/disconnected. Either way I was going to remove it, so need the indicator issue resolved...
I know they have these rings for the self cancel, but wanted to see if it could be anything else before having to take the wheel etc off!
TIA!
