Marlon said:Thanks biojo, I went out tonight and noise gone and lights auto levelling as they should :?
I was going to take it to the local Indy to let them hear the racket but will now wait and see if it comes back
Smartbear said:Marlon said:Thanks biojo, I went out tonight and noise gone and lights auto levelling as they should :?
Did it start making the noise after you had work carried out on the headlight washer? Seems a bit of a coincidence if that’s the case? :?
You know you can change the interval, duration and stop it completely via carly?Marlon said:Smartbear said:Marlon said:Thanks biojo, I went out tonight and noise gone and lights auto levelling as they should :?
Not looked at the washer issue yet Rob. I did however remove fuse 40 to disable the headlight washers as you and others suggested in my other thread. But, this issue seems unrelated as I had the noise before and after I removed the fuse.
Chris_D said:You know you can change the interval, duration and stop it completely via carly?Marlon said:Smartbear said:Did it start making the noise after you had work carried out on the headlight washer? Seems a bit of a coincidence if that’s the case? :?
