Strange buzzing under rear left wing
azazelus
Hi Guys
I usually keep my car in the garage. Yesterday when i started i heard some strange buzzing ( like an echo noise ) inside the car. First i thought the noise is coming from the engine.. but no...
I tested like this: I inserted the key. Switch the key to position 1 ( when all light comes on). There is an electrical device on the engine near the air filter charging .. or something .. for a couple of seconds ... when the key is in the position 1. While this device is charging i can hear a vibrating noise from the left rear wing of the car... just up the left rear wheel. After a couple of seconds the noise stopped but when i start the engine the noise is constant.
The roof motor is working just fine. I tested.
What do you think it is?
Thank you
I just found a post that said the exact same thing. The guy said he solved it with a full bottle of injector cleaning.
hmmmm
