Storage Door Screw Clip
bg1
Need the LHS (are they handed) little clip that the little screw goes in to attach the storage door.
srhutch said:
It looks like you have broken the housing, the clip looks fine.
I managed to get it all apart. The only problem I could see is that the LHS clip is missing the tiny 1mm X 1mm projection that locates in a slot in the housing. I think that has sheared off. The RHS clip has this projection and locks in perfectly?
I am absolutely no expert though.
Looks like the part has sheared like srhutch said. Don't think that's the door, think you're looking at a whole new centre console. Unless you want to try fixing it. Everything is there (screw, etc)...nothing is missing, the part has just broken
You're the 2nd person to say this but I'm sure the other side is exactly the same. It's just that the clip has lost the little nub on its bottom outside that locates in the hole in the console female bit??
I’ll stand by what is said at the start, you need to replace the housing.
https://www.ebay.co.uk/itm/224054101035
https://www.ebay.co.uk/itm/264153648691
Still need one please!
I know you are probably right but I have it all back together and it works perfectly except a little movement and the clip on the LHS (as you look at it) is missing the little tag. So I really want to prove myself wrong first.
Remove your storage compartment cover. That will tell you what is broken :)
