A
Anonymous
Guest
tiggy1985 said:Were all dooooommmmeeeeedddddd to have a £2500.00 repair bill, its a good job I love this car![]()
that's when you trade in for that newer model you couldn't make your mind up about
To me, that sounds like the simplest solution to start with. Surely wouldn't be too hard to attempt I guess?BluZiff said:or possibly some kind of heat shielding around the ECU?
It might deflect direct heat from the car's heater but I don't think you could anything about a general heat build-up apart from cranking up the airconranski said:wouldnt applying some heat reflective material prevent the issue?
tiggy1985 said:Been given the option to buy a steering column from a 07 plate care for £150.00 what do you reckon? Bargain?
ranski said:tiggy1985 said:Been given the option to buy a steering column from a 07 plate care for £150.00 what do you reckon? Bargain?
Has the forum ever done a poll on who has been effected by this and to what degree?
I have a 53 model and have had the heating up full the past few weeks with no such issue (he tempts fate!)
I guess it's just a matter of degree. I've only experienced this back in March when driving for over an hour with the heating on high directed into the footwell, but it was on VERY hot - must have toasted the ECU!ranski said:I did a round trip last week of 150+ miles with the heating on mixed between front and footwell and didnt have any issues :|
But if its only effecting the steering if you only have the heat on the footwell i will try and avoid doing this
GAZA62 said:Very rarely use my footwell heaters allways the dash vents so its not just footweel plus i am sure the ECU sits just behind the dash need to get my TIS reloaded.
Thing is its not just the heaters that can cause this if the car is sitting in direct sunlight this can also cause the same prob as i am sure some of our US members from the hotter states have found out
Ah, that could be what I was referring to earlier in this thread. Not mechanical after all then. Direct sunshine, never a worry in Scotland thenGAZA62 said:Thing is its not just the heaters that can cause this if the car is sitting in direct sunlight this can also cause the same prob as i am sure some of our US members from the hotter states have found out
bigshurv said:Mine's suffered twice in 2.5 years both times when parked in the sun all day cooking. Start it up, close roof n windows,set the climate on full chill for a few mins and it will go away. Not really an issue in the uk., it's never hot enough.![]()
tomTVR said:If its an electrical problem rather than mechanical then why do you need to spend £2,500 on a whole new rack? Surely just a new CPU would be needed?
Just a though but people who build high-end desktop PC's for gaming use micro cooling systems with water jackets around the processor. Sounds dangerous (using water) but its tried and tested. Maybe something like this could be adapted, after all that is a seriously expensive fix if it happens to you.
