LemonConnoisseur said:TomK said:Bear in mind you won't be able to use the car on a TF nurburgring session with one of those (if they spot it).Ed Doe said:quick release
I'll drop you the ncs coding for the light, I'm sure and will be interested to see that it will work on your car, as I said I think other things confuse the issue with mine..
This isn't strictly true.
If they see you with a quick release hub that doesn't have a button that you need to press before releasing the hub, then they don't allow it.
If you have one with the "security button" (I don't know the proper term for it), you should be fine.
As for wheel thickness, thin all the way!
this one has the security button, just visible at the 12 o'clock mark. This car will be heading to the ring likely next year, this year im driving over to Monaco this year in another one of the toys.
