Zedebee said:No, there is a cut-out for the paddles. I can take pics for you in the morning. I think that is the only difference (apart from the holes need drilling).
skmattwell said:Very interesting work guys! Was a pain installing my paddles properly as there's very little documentation about them, particularly when coupled with mfsw buttons
Usel said:Zedebee said:No, there is a cut-out for the paddles. I can take pics for you in the morning. I think that is the only difference (apart from the holes need drilling).
If you can take pictures that would be really helpful, thank you.
Zedebee said:Usel said:Zedebee said:No, there is a cut-out for the paddles. I can take pics for you in the morning. I think that is the only difference (apart from the holes need drilling).
No problem. As you can see there is a cut-out in the steering wheel plastic as well as the trim piece.
Zedebee said:Mine also working! Wired up to the two pin connector on the slip ring, using the plug from the SMG paddles, and earthed to the steering wheel using the same earth point as the airbag.
Really pleased, thanks for pointing me at the Mini paddles, [ref]Usel[/ref].![]()
