Steering angle codes- SOLVED
bigwinn
Lincoln UK
Site Supporter
Hi all
Got 3 yellows the other day and I know the car has a history of steering angle code issues.
I read the codes and sure enough 5E 43 showing implausible angle
I used the 'solved' thread Zedebee popped up to use Toolset32 and INPA to reset- success but the code recurs quickly again (pic attached)
So- whats peoples guidance?
Do I need to reset the steering angle another way post works on the suspension?
Any ideas accepted!
Cheers
Stuart
Ah- followed this guide here to use inpa to interrogate and reset angle
https://youtu.be/8pCNaGayE0o
Steering angle was -500… so that would cause a few codes I guess
Reprogrammed the angle and no yellows come back yet: I’ll keep the thread posted
I love inpa
When I lose my notes in future and if anyone needs the steps on inpa
Select model
Chassis
Steering angle sensor
F5
F4
Note angles
F10 exit
Shift F5
F6 config
Wheel dead straight
F1
F3
F10 exit
Read angle again using 1st steps
Reset codes in main menu
Resurrecting my own thread-
Had to clear the lights 3 times now so its not fixing the issue
Anyone got any suggestions of what to check to resolve?
Steering angle sensor worth replacing?
Swap the column?
Cheers
Stuart
Yeah still works
Going to have a play with the position sensor and the yaw sensors as I have spares
The other telltale issue I have- the DSC and ABS act up prior to the lights coming on (again)
So DSC fires up when slow acceleration is being applied and you can feel ABS kicking in when braking...
Something isnt right overall that the car is trying to over think/react to
Is 5E40 the only code? The fact it’s steering angle implausible and this is what the steering angle sensor measures suggests it is the sensor that is the issue. I did have it apart and it looked OK but that doesn’t mean it’s not faulty.
They seem to be quite readily available for not much money, but it may be a column-off job to fit.
I’ve got the breaker if I need to grab one
Going to get the tracking done first as I’ve a sneaking feeling that after doing the front end works (and the steering wheel is a bit off centre) that may eliminate a few things
fixed
first- get your TRACKING sorted as mine wasnt out, it was OUT OUT
Once thats done re run the Toolset32 program and use INPA to sort the codes
All fine now!!
:rofl:
Great result. I’m surprised you said it was driving so well if the tracking was OUT OUT. Hopefully it will be even better now :thumbsup:
