Hi all
I know there's 2 posts on this but I'm having an issue when looking to replace the starter motor. I'm trying to do this without removing the inlet manifold. Apologies if any dumb questions, but on planning I can't see how to actually pull the motor out the engine bay with this firm foam covered pipe in the way. Is it meant to be pulled under and towards you? I can't see how else to get it out as it won't fit through the gap between that and the bell housing? Unless I'm mistaken.
Car is e86 z4 coupe 3.0si n52 engine with silver top on engine
Faz
Faz
