Hello folks,
Went out to the car this afternoon (sat for either 24 or 48hrs) temps were around 2.5 degrees, not raining but probably a bit humid. Tried to start the car which it did however it almost immediately died after a bit of a splutter. Turned off then turned the ignition back on after several turnovers on the starter she started with again a bit of a splutter but it levelled out. Car revved fine and no lights on the dash, the car is about 45miles from empty.
Drove the car for a while and it was totally fine, run up through the revs with no issue, up and down gears no problems, stopped (once the car was warm) and turned off and turned back on started no problem!
First time I have had any issues like this however I did feel like the car has been a tiny (almost impossible to spot) bit slow to start recently or once started just the smallest (again almost unnoticeably) hesitant when starting.
3.0si E86 now on 92k miles (shes due her next service in 4000 miles and is serviced at my local specialist without fail as required)
Im thinking spark plugs? any one have any suggestions? I will see how she starts tomorrow from cold again but I filled her up with fuel tonight.
