Z Z4 Gaz Member South Hams May 15, 2018 #1 Had a search but can't find the answer. What is the standard ARB size, 3.0i?
B ben g Elite Essex May 15, 2018 #2 Do you have sport or SE suspension? There are 2 sizes, I think 18mm and 19mm (I had a quick Google). Sport suspension requires the larger size bushes.
S Scooba_Steve Elite NW London & Somerset May 15, 2018 #3 Put your vin into real oem and it will tell you for your car. Or call dealer.
C Chris1981 Member May 15, 2018 #4 Ben is right, depends on what suspension set up you have? 19mm rear on my coupe... I have M-Sport suspension. You can easily check with an open end spanner if you can get under the car!? See if the 18mm will fit over the bar, if not try the 19mm.
B ben g Elite Essex May 15, 2018 #6 Are you replacing with like for like or upgraded bushes? I recommend powerflex polybushes for the ARB's. My OEM ones were very slack. The poly ones are much better quality.
Z Z4 Gaz Member South Hams May 15, 2018 #7 Getting some Strongflex Ben. Already fitted Strongflex front ARB and RTAB bushes and have ordered upper and lower inner bushes for the rear today as well.
