Stainless steel pedal set
navid.v
Veteran
Just after a bit of info as I am a bit confused.I like the look of the pedal set bmw does but there is no mention of them for rhd cars only lhd.
Is there a difference between pedals?
As they are not cheap,appreciate your input :)
The aluminium pedals are shown on P23 of the (UK so I presume RHD) Z4 accessores brochure but only for cars with automatic transmission, Part number 35 00 0 410 100. The brochure I am looking at is from 2007/8 though so some items may no longer be available.
Hopefully somebody a little better informed can help, otherwise I believe there are some after market products out there which may be of interest and more reasonably priced.
Well looking at the pic says they are but if they dont say RHD then maybe they aint compatible. Have you checked Real OEM
Not a bad thing if they are not availble for RHD as they look pants :thumbsdown:
I like the look of them,prefer them to the other styles.
I have looked at the Real OEM,and they only mention the automatic ones :thumbsdown:
I have the ones from a 1 series fitted to mine... were going cheap in the parts bin in my local dealer:
Still after a matching footrest that will fit though!
bought a set finally, look great but the problem is the pedals on rhd cars are triangular on the back and the lhd ones are square :headbang:
so,they don't fit! any ideas?
can someone tell if the pedals on E46 are square? if so, what size they are? based on the info on bmwfans.info website, they are, but I rather be 100% sure before do anything about them.
cheers.
