Howcome you didn't go for a more square set up in the end?R60BBA said:hopz121 said:Wheels look great OP![]()
What tyre sizes are those?
Have you lowered it?
225/40 + 255/35
No but planning to!
hopz121 said:It looks pretty low already IMO
Have you checked the springs that are on it?
philbo909 said:Howcome you didn't go for a more square set up in the end?R60BBA said:hopz121 said:Wheels look great OP![]()
225/40 + 255/35
No but planning to!
From the pictures your car looks lowered about 30mm already, definitely check the springs before you buy new ones
R60BBA said:hopz121 said:It looks pretty low already IMO
No but it could go lower.
I’ll check on the weekend.
R60BBA said:philbo909 said:Howcome you didn't go for a more square set up in the end?R60BBA said:225/40 + 255/35
No but planning to!
Good question.
2 reasons:
1. Cost - there are only 2 legitimate vendors in the UK that sell 437m reps (CM Wheels and Skidz) [There is a 3rd vendor in North London but I question their legitimacy]. Skidz sell 437m reps in a square set up and CM staggered, but Skidz were looking for an extra £150 including postage and packaging. (Plus I also managed to get a free set of Bimecc bolts from CM - I highly recommend them).
2. Conservatism / fear of change - I am used to driving with a staggered set up and will be taking the car to the Nurburgring this May. A square set up gives more oversteer and I guess there is always that fear of not catching a corner and subsequently being charged a grand just to fix a couple pieces of Armco. The staggered set up provides me with more predictably and thus less worry![]()
philbo909 said:R60BBA said:philbo909 said:Nice, that's more than enough reason! car looks awesome by the way![]()
Thanks fella![]()
Sorry to revive and old thread but I recently saw on the forums how your Z4 is running a 245 front tire. I wanted to run a square setup on my car, so I was looking between a square setup of either 245/40/18 or 235/40/18. I was wondering if you had to modify anything in order to make the tires fit. I just recently did suspension and installed adjustable koni shocks but I'm on stock m-sport springs. I'm currently in the process of prepping the car for the canyons/track and wanted some help on this. Any tips or advice would be greatly appreciated.not quite a square setup, but I run a 245/35 front and 255/35 rear on 18x8 and 8.5" rims for track work... wider fronts just gives a bit more neutrality to the steering when exiting corners and trying to get on the power - with narrow fronts the car would always want to drift wide on the exit.
oversteer is never a problem in the dry, trackday rubber at a 255 width is more than ample to keep the rears locked down. could still do with a bit more camber on the front though.
I didn't make any mods at all to mine... standard e85 3.0i, standard 8"/8.5" wheels. All i would say is, 245/35 on an 8" rim was probably the max, ideally it would have been on a 9" width rim.Sorry to revive and old thread but I recently saw on the forums how your Z4 is running a 245 front tire. I wanted to run a square setup on my car, so I was looking between a square setup of either 245/40/18 or 235/40/18. I was wondering if you had to modify anything in order to make the tires fit. I just recently did suspension and installed adjustable koni shocks but I'm on stock m-sport springs. I'm currently in the process of prepping the car for the canyons/track and wanted some help on this. Any tips or advice would be greatly appreciated.
