Him said:I was told by venom motorsport that the adjuster on the rear should go at the top, then the spring sitting on the lower rubber pad... I may have put mine in upside down lol... still its a fairly simple thing to sort out haha
Big Andra said:Him said:I was told by venom motorsport that the adjuster on the rear should go at the top, then the spring sitting on the lower rubber pad... I may have put mine in upside down lol... still its a fairly simple thing to sort out haha
I had the same problem. I tried the adjuster on top, bottom and removed completely and I still had the clinking noise. Turned out it was the coils of the springs touching while compressing. I removed them and stuck some eibach springs in instead and I've had no probs since. My adjusters kept winding themselves down also which was quite annoying.
bearded_ed said:Damn, I'm sorry to hear you're having so much trouble with them!
I guess this is the challenge with stuff that has a generic fitment.
Shame too as my shocks are done at 92k miles.
Him said:bearded_ed said:Damn, I'm sorry to hear you're having so much trouble with them!
Found the issue was slightly loose drop link bolt, angry darren is happy darren now, Now I have had a bit of a drive on them now, i would actually say there pretty decent, with the spacer car feels stable even when pushing on. Alignment next should hopefully see better things still.
Smiffy2k20 said:I’ve got this issue on my coupe with the clonking on the rear which was the exact problem I had with the joms
Venom told me to fit the adjuster at the top without the rubber pad so I’m going to have a play tomorrow at fitting the rubber back in and adjuster at the bottom, the springs are binding with it just sitting so if it’s the spring making noise I will have to speak to them about it
The kits in the US I see the adjuster at the bottom with a bolt and washer locking it to the lower arm
