just-right
My Z4M is near the two year limit on its oils so it was time for some spring and summer prep. 8)
- 6L Castrol Edge Supercar 10W-60
- 1L Castrol DOT4 Brake fluid
- OEM Mahle oil filter
As I was about to start it appeared my trickle charger wasn't quite doing what it was supposed to do and knackered the OEM battery. I found a good deal on a Bosch S5 A08, which is also an AGM battery. The Bosch one looks almost exactly the same as the OEM BMW which makes one wonder... The only differences are the cold crank Amp and the presence of two vent holes. You have to plug one and connect the other to the vent tube. The Bosch S5 A08 is also 0.4 kg lighter at 20.1 versus 20.5.
I have managed just shy of 4000 miles in two years. The drain bolt took a bit of force to get out but replacing the oil filter was an absolute charm. The oil although clearly starting to get contaminated with various deposits was still looking pretty decent. My car is at 47800 miles so I bought a Miller oil analysis kit as well. I primarily want to see what the lead and copper content is.
http://www.millersoils.co.uk/services/oil-analysis
I still have to do the brakes but will do that later. Once I have shipped out the oil sample and got some feedback I will post it here.
