Go to https://bimmer.work and put in your VIN and see what options you have. (Access the site with an ad-blocker installed on your browser as it's a bit ad heavy!!)Portisz4 said:How do I know if I have a com box
Nothing else in the 600's? You MUST have 609, as that's iDrivePortisz4 said:I have 6am 6ah 6ak
Interestingly it thinks I have an automatic gear box too ! That's odd
Portisz4 said:609 654 620![]()
Yeah well that would explain a bit then, 6NH is also Bluetooth callsPortisz4 said:6NH !! Sorry not 6ah my badthat's why you can't find it.
You say ..So coding 633 (Bluetooth calls),
I already have bt calling ??
Radio, nope, not interested in some boring knob droning on, just music for me thanks.Pondrew said:Does anyone not listen to the radio anymore? Or music via a USB flash drive, or good old fashioned CD.
Have a look at this photo (stolen from another post on here), ignoring the red boxes the Combox is within the yellow oval, and this is behind the carpet sectionPortisz4 said:Still can't find the Bluetooth audio box to check though![]()
McHaggis69 said:Thought I had missed a trick here. Have been using a cable into the aux in the centre console to get spotify.
Check on Bimmer and I have codes -
6NF Music interface for smartphones
6FL Usb-/audio Interface
609 Navigation system Professional
Amongst other codes in the 600 range.
I'm not seeing an audio option at all and have screens same as Portisz4.
I assume I am missing the correct option for bluetooth streaming. Followed the youtube video and no option to add audio for me.
As I originally stated, for Bluetooth streaming you need 644, 6NF is for smartphone apps integration (ie; iPhone direct apps onto the iDrive system). I will correct my error :?As long as the combox is definately there, so I'm assuming it is, then it can be coded. You need BMW Tools, which includes INPA, NCSExpert, Tool32 etc (Here>>> https://www.bimmergeeks.net/downloads), but then you need to know how to use it. If you are prepared to wait a while I've just relocated my Combox into it's proper place (I originally retrofitted it above the glovebox but decided to move it for the video) and will be making this into one of my How-To videos for a full retrofit which will include the coding side of it (basically some of which you'll need to know). Alas I don't know when I'll be releasing this video as there is a lot of other work to go into the video which I've not shot yet or compliled. I may be able to write down what you need but it's not straightforward without a video to show you, if you see what I mean.Portisz4 said:Can it be coded in? I have that cable thing and the BMW software ista or inpa what ever it was. I think it came with coding software . Is it complicated to do to add bt streaming
