Sport setting
IZB
Hi folks.
I’m trying to figure out the difference between the Sport and the Sport+ settings. the BMW manual is pretty vague about what actually changes, for instance is DTC switched off in the + setting?
As far as I’m aware the dct doesn’t switch off in sport plus setting.
In sport you get sharper throttle response, tougher suspension, and the gearbox holds the gears longer. In sport plus it’s all of the above but the gears really hold even longer. It also allows more slip on the traction control. Oh and steering stiffens up in sport mode.
Thanks Ori, so basically Sports+ is more intense 👍 but the safety features remain in all settings.
On the g29 they do, but loosen up a bit I believe.
I’m hoping someone more technical will give better info! ;)
Having just done the Pyrenees I can confirm they do “loosen things up a bit” :rofl: :rofl:
If you go to sport individual configuration page, you will notice that engine, gearbox has comfort, sport and sport+ whereas steering and chassis only have comfort and sport.
Basically, for engine, sport+ will give you more aggressive throttle response than sport which is more aggressive than comfort. Both sport and sport+ will open the valve and change the map so that it will be louder and pop a tiny bit.
Then, gearbox sport+ will hold on to gear longer than sport and shift more aggressivly than sport. Also, it will disable the auto upshift.
About the DSC, it's now can be configured individually than the driving mode. You can enable DTC even in any driving mode or disable the DSC in any driving mode as well.
[ref]q96169we[/ref], what does moving the gear shift to left do to engine and gearbox? I think it holds the gears even more in that mode.
So even in normal, you can have the gearbox in sport mode by shifting to the left sport mode.
One thing it does is stop it “auto shifting” up when it hits the limiter so allows you to hold gears exactly like a manual, don’t ask me how I know :wink: :D
We had a long discussion about this between myself and the manual drivers on the Pyrenees trip when we were discussing the pro’s/cons of the G29. I then tried all permutations over the next few days and came to the result it can be driven like a manual gear-change wise :thumbsup:
On my 440 (with the same drivetrain as an M40), you can leave everything in 'normal'; then turning the DSC off manually opens the exhaust valve. I presume the G29 would be the same. I do it all the time cos I'm an anti-social git (and it saves wear on the rear brakes). :thumbsup:
No you can't. On G29, the valve control logic is speed, gear, and driving mode related. Even if you are in sport+ with DSC in DTC or OFF mode, but within a certain speed and gear window, the valve is still closed. On the other hand, even if you are in comfort or ECO Pro mode, the valve can still be opened in certain speed and gear window. I think this is related to how the EU regulation defines the noise measure procedure.
That's a mode defined in the gearbox instead of body domain control (BDC). I personally consider the BDC driving mode is like a set of global parameters passed into each individual component whereas S selector position only a local set of parameters affect itself only. Those two set of parameters can have some overlap but will also have some difference. For example, BDC mode has four parameters passed into gearbox (assume A, B, C, D). Then, gearbox S position has also four parameters to change (assume A, B, C, E). In this example, if you only put the selector to S, parameter D will still in default one whereas if you select sport+ mode, D will be changed as well. Similar story for parameter E as well. Sorry if this example is a bit more confusing than it already is. :headbang:
If I remember correctly, you can consider the main difference between D and S position is disable/enable launch control. I think even if you are in sport+ with DTC, if the gear selector is still in D, you still can't engage the launch control when other conditions are met.
Long press the green circle button will turn them off. Or, you can set to individual and configure the individual to turn off certain features.
[ref]q96169we[/ref], so today I put it in sports plus mode and then shifted the gear lever to the left and the car dropped a gear. So even in sports plus there is an extra sport mode. ;)
But, it will upshift if you don't keep pushing hard, which will match whatever gear the car was in when you are in sport+.
My finding of the control logic when switching driving mode is that each time you put the car into a more aggressive mode, the gear box will drop one gear firstly unless it's in the lowest possible gear under current speed. Then, the gearbox will try to keep the engine rpm in a certain range if not pushing. For example, if you are in 7th gear in comfort at 1200rpm. Comfort -> sport will drop to 6th. Sport -> sport+ will drop to 5th. Gear lever then change from D -> S/M will drop to 4th. Now, let's say you keep driving normally at constant speed, the car will then shift back from 4th -> 5 or 6th to keep the rpm within a certain range (sport is around 2000-2500rpm, sport+ is around 2500-3500rpm, gear lever to S/M is also around 2500-3500).
