What's driving me nuts are the incessant questions of "how do I work my car?"crikey that would drive me nuts !!!
NO. It works from the speed sign recognition camera (mounted on the windscreen). You can set an alert ONLY if you exceed the speed for the speed it detects from the sign. You can't pick and choose which speeds it alerts or not. So it's on or off.But only to the actual speed limit. For example: if the speed limit is 30mph then if you go over that then a notification. If the speed limit is then say 60mph is would only react to the 60mph limit - not at 40mph or 50mph.
A bit fanciful I guess
