Speed Camera detectors
Self adhesive pad. Not removed mine so no idea how sticky it is.
Feared you would say that ... surprised manufacturers have never come up with an alternative .... thanks
It's a 3M adhesive pad - recently changed the X3 and had to remove it from the dash to go in the new X3 and it came away without leaving any residue
Perry - I was going to run mine off of the cigarette lighter in a Z4C - Where did you feed the wire from the back of the c550 around the side towards the door? or down the back? Thanks
if I go into unknown I'm always with my tom tom GO app on the phone! seems to do well as far as speed cameras etc go.
not as "current" as waze but it does the job.
driving inside m25 is pita, I have like 20 cameras in a 1.5mi radius
I hardwired into the power supply in the rear-view mirror housing (same as for a dashcam) then fed the power wire along the top of the windscreen and down inside the A-pillar, with it cable tied to the existing wiring loom - but I've got a roadster so it's fairly simple to remove the trim that goes along the top of the windscreen and the A-pillar trims, I've no idea how easy that is in a tintop...
