Validwarlord
Hi All
I have a Zed that has the 6 speaker system and I was after some advice as I would like to add the door speakers which I believe are called Tweeters which fit behind the triangle plastic piece on the top of the door trim?
Does anyone have a set for sale (standard) is ok for the time being as I need other bits to purchase before I upgrade the speaker system to
B & O or Harman Kardon (Other makes are available
Will these need any type of coding, I remember watching AnubisZed’s video when he upgraded his speaker system and they look to plug direct into the door speaker which requires the door card to be removed?
Also there is a space for a centre speaker which is behind the seats could this also be added or is this more of a case of having the amp etc.?
And finally there is a space for a speaker in the dashboard again would like to do something with this?
Dave
)?Will these need any type of coding, I remember watching AnubisZed’s video when he upgraded his speaker system and they look to plug direct into the door speaker which requires the door card to be removed?
Dave
