Speaker wiring help
Z4C_er
 Wiltshire
Hi all, I'm at the stage of adding a wire into the door for the mid range speaker. I undid the connector at the door, and just having a squizz at it now. But before I proceed to make a mess of it, how can I add another wire through here? Thanks in advance for your help.
Davz said:
No need to, just tap into the tweeter wire.
Thanks, but I have a crossover that I need to install into the car side. I Have the tweeter cable as is, but I need to add another from the car side that comes from the crossover.
Any suggestions?
There some empty spaces in that plug you can either buy the correct pins , or have at look at this but not sure if this is possible on that plug with those hole sizes,
https://youtu.be/UfHEHeQXmxE
This is from an E90 post. Apparently this guy looked at drilling a hole in the plate above the connector (circled) but ended up slipping the cable below (arrowed), as there was a gap also. Apparently no problem. I'll try the same.
