Hi all
I've spent a while searching the forum for info and found some good info but not everything I need.
I have a 2007 Coupe with business radio head unit and standard speaker set up. I think that means 2tweeters in the mirror housing, 2 speakers in the doors and another 2behind the seats. I have cubby holes behind the seats so the speakers are, I think, above that behind the mesh.
I'm looking to upgrade the speakers in the doors and the tweeters but trying to find which speakers will plug and play with minimal cutting of wires and trims is not easy.
From what I can gather, these will be good in the doors
https://caraudiosecurity.com/ecx100-3-2-way-10cm-speakers
As far as tweeters are concerned, I'm unsure. There are a few at 25-26mm which I think is the right size, but unsure if the grill on the tweeter is removable, or would need to be cut off.
And I know that I'll likely need some sort of adaptor plate to connect a 4screw speaker into the door card with the 3mounting points.
Can anyone confirm if the linked speakers would be suitable, and if anyone knows of suitable tweeters and adaptors I'd really appreciate some links.
Thanks in advance.
Thanks in advance.
